SuIiCiDaL wrote:is it possible to change the sh*tty cvt tranmission on the 2.5s. i was wandering it and i know it will cost a arm or a leg for it. I WANT IT BOOSTED
Yes but it will cost you a lot:
You need:
1. Manual transmission.2. Clutch Assembly.3. Pedals.4. Shift Linkage.5. Shifter.6. Transmission mounts if they are different.7. Possibly a different ECU.8. Cut floor for pedals, etc.9. Pray it works.
You're looking at at least 5 grand all said and done if you're not going to install it yourself.
