dcg129 »
https://forums.nicoclub.com/dcg129-u77311.html
Mon Oct 29, 2007 4:58 am
Also, running low on oil hurts the timming chain due to lack of oil. A nissan timming chain has a normal low grade ticking sound. They are very sensitive to failure when you run low on oil. I notice when my oil gets towards needing a change I can hear that sound louder. when the oil is new, i don't usually here any ticking sound from the chain. Your Syn oil should not have been the problem. I would lean towards the PCV fix previously mentioned. I did notice if i used to low a SAE grade on other cars, 0w-20 or 5w-30 when the specs called for 10w-30, it used much more oil. Also, at high speeds you lose oil faster. On long trips at high speeds it is impt. to check every fuel stop.
