biasbob »
https://forums.nicoclub.com/biasbob-u106524.html
Sun Sep 21, 2008 1:26 pm
I took off the throttle body, and it seemed very stiff. Having never worked with a drive by wire vehicle, I don't know what it's supposed to feel like. I sprayed a bunch of throttle body cleaner on it and got it nice and clean, it then would spring shut by itself, although it slowed down as it neared the closed position. I got it to start, and idle very poorly, never revving above 2500rpm. The AllData suggested that safe mode was due to a failed return spring. It seemed like there was a bunch of goo that was making the throttle stick. I started it and turned it off, waiting the 10 seconds in between, and on the fourth or fifth try it seemed to run normally. The idle seems a little high, around 11rpm in neutral. I turned it off and restarted it about 6 times, worked the same every time. The service engine light is still lit. I took it for a test drive and it seemd to drive fine, plenty of power and smooth idle. I forgot to take over my laptop with the EASE OBDII software so I couldn't clear the code. [car was disabled over at my daughter's house]. When I clear the code, do you think it's fixed?Thanks,Bob
