Twilight sentra tuner »
https://forums.nicoclub.com/twilight-sentra-tuner-u65262.html
Thu Jun 28, 2007 2:42 pm
to remove the thermostat, drain ur coolant system first. make sure the engine is cold. next, remove the retaining bolts that hold the thermostat housing in place. after the housing is removed, u can pull it right out. remember what position it was in so u don't put the new one in backwards.
to put the new one in, first scrape off any leftover gasket material. a puddy knife will do the trick. then put the thermostat in and install the housing and new gasket. tighten the retaining bolts, install the radiator house, and fill the system back up with coolant and u should be good to go.
