Altima 2000 Instrument cluster removal.. Please help
General discussion area for the L30-chassis Altima
elacesar
Car: Nissan Altima 2000
Can anyone help me on the removal of the front gauge panel because the the needles are spinning uncontrolably and i believe that it might be some wire loose which is causing the problem., Any help will be appreciated.. Thanks
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
When I get home from work, I will try and locate the dashboard removal pages and post them up.bud
elacesar
Thanks for the help..
Cold_Zero
Sorry for the delay elacesar.There is a ton of documentation for the gauge cluster. Just let me know if you need more.
elacesar
Thanks alot COLD Zero too bad the pics are a little unclear but its perfect. I just wanted to figure out how to get the plastic trim off. Thanks a million
Return to “2nd Generation Altima Sedan (1998-2001)”
