Looking at buying a set of 18" 350z wheels. They are from a 2005 350z and are mint w/ only 500-800 miles on the wheels and tires. They have been stored in a garage and the guy sold his Z, so the wheels need to go. Stats on the 350z wheels are below. Will these work on my 2008 2.5 S Altima Coupe? I figure I will run the stock rear tires for a while, then later switch them to 22/45/18 to make the front. I might lower my altima 1-1.5" sooner or later so not sure if rubbing could be an issue or not? Let me know what you think.
Size: 18x8.0 Offset: +30mm Weight: 24.4 Tire: 225/45/18
Size: 18x8.5 Offset: +33mm Weight: 25.8 Tire: 245/45/18
Modified by KGNickl at 1:34 PM 8/2/2008
