R U talking about the factory 6 disc changer? There's two of them, the one that sits in the center console that comes with premium package, non navigation systems, and the one that sits below the center console, that is seperate from the radio, etc.nishantsanghvi wrote:Hi,
I have Altima 08 SL. It does not have a connection package. I was wondering if I can install 6CD changer (MP3 compatible) in place of existing non-bose single CD player.
If Yes, how and where can I get one.How much would it cost?
Awaiting Replies ASAP...
Nish
I understand what you want to do, but there are a number of limitations and reasons this is not feasible... I'll touch on a few of them that Applebonker didn;t mentionnishantsanghvi wrote:I have attached an image which shows the 6 CD Changer (Factory installed). The difference is that I have the same panel, its just that I have a non-bose single CD system which I want to replace with the item as shown in the image. AS for the speakers I would be keeping my same old speakers.
Is it possible to do this. Also wanted to know, if I go ahead and do this replacement, will it have any effect on the audio controls placed on steering wheel?
http://picasaweb.google.com/ni...nger#
Since you don't already have an amp in your trunk, the wiring in your car is COMPLETELY different from what is in the car that comes with the Bose unit. Anything is possible, but this would be an incredibly difficult install. You would essentially need to rewire the entire car. Also, the speakers are different too (different impedance I believe), so they would need to be changed as well. All of this is not worth it IMO.rbsmith2000 wrote:I happened on a salvage deal for $350 (complete with shipping) for the Connection Package version of the changer with an aftermarket amp. The changer comes complete with the dash panel and environmental controls for that price. Do you see any complications with using the panel and the environmental controls in my 08 2.5s (manual tran)? It has an 'auto' button that looks unfamiliar. Does that require more electronics to get that to work or ???
I'm pretty sure the base speakers are 2-ohm. The best way to check that would be to pull one out and look at the back (it should be printed on there). Or, you could connect it to a multimeter and see what that reads.rbsmith2000 wrote:I see your point on the wiring and impedence. That's why I went with the after-market amp. It's smaller and less powerful than the Bose version and its heat dissipation is low enough so it can be installed in the dash, if the space is adequate. It should be able to push the existing speakers and match their impedence, as well as solving the wiring issue.
Do you know what the impedence is for the base 2.5s speakers? It would help me set the impedence on the amp.
I'm also concerned about matching the environmental controls to the systems in the 2.5s. Do you have any hints about that?
I've read similar instructions before. Those are only useful if you can recognize the point when distortion begins to occur. It's far easier to first set the gains with a multimeter as outlined in the FAQ.rbsmith2000 wrote:Thanks for the heads-up on the input gain issue. I've saved this link in my Favorites.
This little amp does have dual gain controls (front vs. back). The instructions are a bit funny: Start low and turn up the gain until distortion begins. Would those be adequate for the gain differential you mention? Here's another link from another vendor.
No, those climate controls are dual zone (driver/passenger). The A/C has vents under both the driver and passenger seat, but there are no other vents in the rear. It would be easier to not have to move the board to your current head unit, so I'd give it a try at first with the dual zone climate controls. Like I said, I'd be surprised if someone hasn't already tried to do this as seems like it would be a value-added mod. I don't have time to right now, but I'll try to look at the service manual to see if this is even feasible.rbsmith2000 wrote:Regarding the environmental controls, I think the unit in the salvage package is for back and front ventilation. I don't have ducts on the back of my console, so that probably rules out using this control. I checked the plug on the back of both units, though, and it appears to be the same. I am leaning toward moving the entire changer, including the front board to the car's original face plate. It won't say 'changer' on it, but I can't say I am concerned about the labeling.
I'm not sure how easy this would be to do, having never done it myself. If you try to go this route, let us know how it works.rbsmith2000 wrote:I took apart the salvage audio unit, including circuit board. It was a bit unexpected in construction, but if you are telling me the display panel will work between the changer circuit board and the OEM display, the space issue may drive my decision.
Doc did a write-up with pics on here as well. This is linked in the FAQ.rbsmith2000 wrote:BTW2 - This link was helpful for pulling the audio unit:
I've never heard of that. But I didn't really have my Bose head unit in long enough to even play with it. I think I only ran it for a couple of weeks when I first got the car. Maybe it was a bum unit since it was salvaged?rbsmith2000 wrote:Are you familiar with this error?
Unfortunately I don't believe this is possible. There would be some gaps/holes between the climate module and the trim piece. Here's a couple of pics that hopefully show some of the differences:rbsmith2000 wrote:Yeah, the changer unit was actually DOA. After playing, poking, shaking, inverting and cursing, it wouldn't play, wouldn't eject. Also, it looks like CDs are (trapped) inside. On to plan 'B'.
Do you know of a trim piece or kit that would accommodate a manual environmental control in a automatic opening?
