Hi all
Hope I might be able to get some help regarding my idle vibration.
I will start to say that I am a kind of perfectionist and its not a matter of very rough vibration but rather a slight vibration on idle in drive, felt in the steering wheel, pedal & seat. Sometimes it goes away but felt stronger on a cold engine. I think that it's better in moist weather condition, does that make sense?
The vibration is only in drive and parking and neutral is flawless.
Had the car for a year, it has 106k miles and I have already done the following:
1. Replaced front, transmission & passenger mounts
2. Replaced cranckshaft & camshaft sensors
3. Changed plugs
4. Did oil change and filter
5. Cleaned the throttle plate and relearned the idle
It seems I always had this vibration and it got better as I did the above but it's still there.
I have added this verio that shows the engine as I move to drive and add load such as ac and lights. I am thinking that maybe the rear mount, the only one I didn't replace, is responsible for this and I wanted to get some professional advice.
http://youtu.be/NckkQA832xE
Thanks
