ZGadson »
https://forums.nicoclub.com/zgadson-u56225.html
Mon Sep 22, 2008 2:49 am
To be honest, I wouldn't use an oven. Aftermarket plastics are far less dense than stock parts and also lack quality. You could still do your mod, I just wouldn't heat the whole thing up to pry off the lens. If the whole lens is heated, it makes it even more flimsy and more likely to shater when prying it off the housing.
Maybe use a heat gun around the edge only to losen the lens?
Modified by ZGadson at 6:04 AM 9/22/2008
