So this has me baffled, I found the wiring diagram in a chilton manual which is rather vague, shows a rectangle for an alternator, with two wires running to it (3, but 2 of the same color connect together before reaching anything) I don't have a scanner but I'll take pics of everything tonight. The napa website lists some 20 styles of alternator for this year, yet none of them have my plug style. I'm running myself around in circles, and remember why I have an aversion to wires. But I'd rather learn something here, and with help I am hoping to get this thing wired right, save 100 bucks, and get it done now, not weeks from now.
<img>
http://partimages.genpt.com/thumbs/728261.jpg</img> See if this link shows.
Any clue what S and L(L/TRIO) stand for?
I am also confused on the diagram captainzeros posted. Anyone know for sure which prong is which on the T that connects to the alternator? Looks to me like the | part of the T is on the bottom connected to the W wire. On my alt the top of the T is closest to the edge of the alternator and is the same with every T plugged alt I saw on the napa website.
Does anyone have a good tip on how to figure out which wire goes to what? I am hoping there's a easy way to test this, I'm just not sure how to approach it. It seems one wire goes to a fusible link, then eventually makes it to the fuse block, and the other seems to go to all sorts of pin conectors.. sensors? auto choke, voltage indicator. OK say I hook up the battery and throw a jumper from the pos terminal to the striped wire, I should be able to light up a test light at one of the plugs on the choke relay right? or doing the same to the white wire I should get juice to the fuse block without having to turn on the ignition.
I apologize for so many questions, the last thing I want to do is screw something up. I did take an electronics class, but I also fried half my parallax circuit board before the semester was out.. lol ok, heading to the garage with camera.
