EstoMax wrote:del82 i said .05 not .5. I would be worried with a .5V drop too, thats excessive. I guess I'll check voltage drop on the alternator/battery line to confirm that. Do they sell this cable seperately or is this something i buy the parts and make? Haven't replaced this yet .. haha
cheersMarko
Haha...well, that's me once again proving why I wear glasses. Anyway, yeah, .05 is actually excellent, and don't worry about the headlights dimming a bit at idle, that's also very common. It's got more to do with the amount of power from the alternator that's actually available at idle, which isn't anywhere near the max output. The motor bogs momentarily because, well, imagine someone stepping on the back of your shoe while your walking. Since you don't know its coming, you'd stumble just a bit before turning around to backhand em so long as the idle corrects itself within a second or two, nothing's gone wrong.
If it's still bothering you, and/or you just feel the need to tinker with it, you can pop off the IAC motor and clean it and the port it sits over with some fuel injector/throttle body cleaner. That might help get some of your idle response back.
