sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Wed Nov 05, 2003 4:17 pm
Ok, the deal with my alternator:It was beginning to go bad, but I thought it was my battery, (which died, of course since the alt. wouldn't charge it anymore) so I got myself a Optima Redtop, it worked great for a few days then the SAFS started showing the voltages dropping to below 11 volts and I figured I’ll replace the alt. So I got another alt. I had lying around, got a new Redtop (exchanged for the one that was drained at PepBoys), and everything seemed fine, the SAFC would read 14.3 volts after I started the car and revv it a few times and let it idle.
Recently, this is what’s' happening: I turn on the car, voltage shown is 12.2.After I drive for a while, it starts going up and down with the revvs, so at 5k rpm (without the lights or any other accessories turned on) SAFC shows 15.9 volts, the dash goes very bright, and at idle it's about 14.2.
The thing is that if I apply my brake, turn the lights on, and am stopped at a light, the dash will dim so that it's WAY too dim and I when I apply brakes the volts will drop to 13.5 and keep going down, and the headlights will dim a little.
I don't understand much about alternators, but I don't think they are supposed to put out more than 14 volts and that it should do that constantly, and no dimming or brightening of the dash/headlights should occur. Is my new (old) alternator also broken? It won't put out 13+ volts until I revv the car past3k, and then I have to drive for a while to make it keep it up there.
Is there a voltage regulator somewhere on the car? It seems something is off. My idle sometimes stays at 1500rpm in neutral and sometimes drops below 700...
Any input is welcome,
sil80
