alternator tensioner pulley
dernvon
Car: 1995 q45t
1991 Silvia s13
pulley came rolling out from under the car last night. Went and bought a replacement, i am on the install but the pulley is rubbing the mount. Am i missing a shim? What am i doing wrong?
bruce2
Car: '91 Q45 Base
The part number is 11925-66U02. The ones from local part store usually are wrong in size.
dernvon
Car: 1995 q45t
1991 Silvia s13
Will have to run and check the box. Looks identical but only came as the pulley. No hardware like the silver shim
dernvon
Car: 1995 q45t
1991 Silvia s13
And while your here, my signal relay is constantly clicking. I do have signal lights when i do use the switch on the column but goes back to clicking. Is this my switch itself? Possibly the hazard switch?
dernvon
Car: 1995 q45t
1991 Silvia s13
Actually the silver part is the duet guard is it not? i do have the right pulley but it is rubbing its housing for the mount
IThaJ0kaI
Car: 96 G50, 90 S13 hatch
There is supposed to be a 1/4" alignment spacer behind the pulley itself.
dernvon
Car: 1995 q45t
1991 Silvia s13
Okay. Is it supposed tp come with the new pulley? Seeing as mine came with no hardware
IThaJ0kaI
I have never purchased a pulley, so I honestly have no idea. I may have a spare set of hardware, on one of my parts VHs, I will check the garage tonight.
dernvon
Car: 1995 q45t
1991 Silvia s13
Alright thankyou
IThaJ0kaI
$10 to cover shipping and it is yours, the bolt for the adjuster is bent but you shouldn't need it anyway.
email me - [email protected]
