I believe manufacturers put bolts in places for a reason...call me crazy or just right....hope the vibrations don't loosen your altenator up and cause your belt to fall off when your 100 miles from home with no tools it is a $2 fix.YOUNG240SX wrote:The tension bolt is some thing that really not need like that both my 240 didn't have them cuz they broke...cuz most of the time when u go tight them for tension they break.have a buddy with a tire iron and side the iron under it push or pull(what ever u think would be easier for u) alternator so to give it tension but make sure u keep that tire iron in place once u see the belt it tight.so then u go and tighten the upper bolt on the alternator and u should be good to good.make sure once the car is on and runnin to check if it need to tighten better.I just did my alternator last weekend not a problem. Idk if this is goin to help u.. But my cent .2 have helped a few
Thank u ryan!!ryan15 wrote:call em crazy but b series honda motors dont even use a tensioner bolt... so if a honda doesnt im sure it would be just fine.Ryan
Yeah, I'm talking about the short(er) stubby bolt. Does anyone know it's length? I believe that it is an M8x1.25 bolt, I'm just not sure about it's length. The one I have in there temporarily is about an 1" or 1.25" long and is too short (it goes into the alt. but not far enough to hold good)got_chub wrote:the short stubby one that the other bolt screws into is about 10 buck at the dealer and the long one is a bit less
If it were a HONDA motor we wouldn't be talking about a 240sx which DOES have a tensioner bolt HONDA=FAIL andso did that postryan15 wrote:call em crazy but b series honda motors dont even use a tensioner bolt... so if a honda doesnt im sure it would be just fine.Ryan
They keep braking because your suposed to loosen the on on the alternator before you adjust it. Then tighten it back up to like 30 ftlbs.YOUNG240SX wrote:The tension bolt is some thing that really not need like that both my 240 didn't have them cuz they broke...cuz most of the time when u go tight them for tension they break.have a buddy with a tire iron and side the iron under it push or pull(what ever u think would be easier for u) alternator so to give it tension but make sure u keep that tire iron in place once u see the belt it tight.so then u go and tighten the upper bolt on the alternator and u should be good to good.make sure once the car is on and runnin to check if it need to tighten better.I just did my alternator last weekend not a problem. Idk if this is goin to help u.. But my cent .2 have helped a few
