alternator---???
shally2186
Car: S14.5
my RB20DET is acting up an sqeelin back when u first start it..once it warms up it stops..however,the lights go very dim until it starts sqeelin,then while its still sqeelin they get really bright..after all that and its warm they arent as bright..do i need a new alternator,and if so then where the hell can i buy a new one???engines a mess,i will appreciate any advice.........
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
i know tophat sells them for the 25 you could try checking there?
S13 240SX
Car: 93 Mazda Miata
use a ka24 alt.. i did it and it worked intll my goold old ka alt died.
have to custom fit it .
Joe
1) tighten the alternator belt
2) replace the alternator belt, if step 1 doesnt fix the problem.
govtworkhorse
Car: 95 240sx SE, 95 240SX, 91 Festiva (DD), 03 GSX-R 600
If I remember correctly, the N/A 300ZX alternator is the same.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
^^What Kamin said^^.
craz4240
Car: 1995 240sx w/rb20det
Tensioner backed out and belt is slipping simply tighten the belt .
shally2186
Car: S14.5
ok ill check my belt tonight..hope thats all it is...thanx
S14eva1
Car: S14 aka "The black bandit"
Can someone confirm if the NA Z32 alternator will work on an rb25?
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
Not sure about the Z32 but I know the Ka24e alternator does. You just have to notch out the bracket a little more for a proper fit.
mello88
Car: s13
What they said.... Or another option... Nissan Quest 110amp alternator. It's not a direct drop in, there is some slight modification/fabrication you'll need to do. But it has another 20-30amps over the stock alt. Search on this topic, there are some good threads on it already.
GL
