Alternator
1989240sx
Car: 1989 240sx and 1974 duster
my buddy has a 2000 frontier i was wondering if he could a bigger Alternator with more amps if some what should he get so he can thanks for the help guys
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
VG33 engine? A V6 Quest alternator is 110 amp and I believe it will swap in if you change over the pulley.
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
EDIT
If you really want a higher output alternator you can contact Mean Green who can sell you an OE style alternator with a heavy duty winding that will give you better than 110 amps. The best part is it will fit with no diddle-dorf-try-to-make-it-fit work becasue the core came from an Xterra/Frontier.
The other option you have is a stock alternator can be rewound by a shop that rebuilds alternators and they might rebuild your stock unit to put out more amps just like a Mean Green unit.( I have one shop here in Calgary that can do just that). The only difference is you have to wait a few weeks to get it done by this local shop.
XterraVersa
Car: 2002 Nissan Xterra
Nissan 350Z Nismo
The Xterra must be a little different than the Frontier. I tried a Bosch alternator made for the quest in my X. After three failures of the Bosch in 4 months, I got a total refund & went with the Mean Green. It has been trouble free for over a year now.
The Quest Bosch alternator fit perfectly.
1989240sx
mean green where can i get it do they also make alt for a 240sx i want to upgrade amp in my car too
XterraVersa
Nissan 350Z Nismo
Luv2ski35
Car: 2002 Frontier lifted and beat hard
I forget what year Quest alternator I got, but the paperwork that came with it said it had 130 apm output.
I have had it rebuilt once in 2 years....but I also kept the frontier alternator as a spare....I go through alternators pretty fequently.
N
