Alternator
240240
Anybody know the # for replacement alternator for the rb20 series motor? Anyone know if the 300zx will work ????
Thanks
rb240det
Car: 1991 240sx Hatchback and 1994 300zx
Correct me if I'm wrong...but I think the KA alternator will work. Not sure if there is a difference between the KA24E and the DE though. But I think there is some slight modification you have to do. Someone can probably give you much better details than I....
rb250sx
Car: '89 s13 w/ RB25DET
'07 Nissan Frontier
'14 Jeep Rubicon
If your using the lower harness from your KA, i beleive the SOHC has the wires switched on the alternator. I know i had to swap the wires on the plug for my 25 when i swapped the regulator from a DOHC.
Wulfgang
You're killing me, 240240. You've got THREE threads on this alternator problem. People can help you better if you keep it all in one thread. That way everyone can keep up with your progress, and we will have (hopefully) better suggestions.
Keep it in one thread, preferably with a descriptive topic title like you did the first time.
Wulfgang
Btw, I don't think your alternator is the problem, but if you search, you'll find that you can use the KA alt. with some small modification.
matt_calgary
Car: 1989 240sx
only modifying that you have to do for the alternator to work is that black bracket....ream out the center hole going NW
240240
I got it fixed guys, one of the small wires that comes out of the plug on the alternator was shorting out, therefore not charging my battery
Thanks
