BACKGROUND: I replace the alternator with an Advanced Auto reman. This was diagnosed by checking battery (it died and was replaced) with a multimeter. Read fine while sitting, but was not right once started, so I replaced the alternator.
CURRENT PROBLEM: The car won't start. Lately it has seemed like the battery was weak, as in starter seemed weak. I checked again with multimeter and it actually reads a little high, like between 12.5-13.5v. It still reads this while sitting, but the car won't start. When cranking, the multimeter drops much, I remember seeing 2.6v. And since replacing the alternator, the lights "pulse" and dim, getting progressively worse.
QUESTIONS:
1) Would a weak/going-out starter act like a weak/dead battery?
2) (I'm going to ask Advanced Auto this as well) Is there a way to test the alternator without removing it?
3) Are the regulators integrated in the alternator? Would those be the likely source of lights acting up? Or the alternator itself?
Thanks for reading this and any help. I am not so sure I want advise like "don't buy Advance Auto parts, they're junk" or similar, unless I can get better quality for nearly the same money. I know I am fixing a problem that might be caused by their alternator, but I have lots of time, but not a lots of money. My choice, just so you know, but now that I say that, maybe someone can convince me to treat the Q better.
