Alternator Spark
marryson
Car: 240sx
I have a 93 240sx. It was 100% normal until I make a SPARK while I was changing the alternator belt without disconnecting the battery. after I have everything tightened, the car starts but I get no electricity unless the engine is running. And the key is stuck as well. I couldnt get it out without forcing it out. according to my research, my FL750A Alternator fuse is blown. but before I drive 2 hours to the Nissan Dealer, is there any other suggestions or ideas of what is going on?
Something else I should mention, the car started running abit weird after this. when I rev the car, it doesnt seem like it wants to go above 3000rpm and some poping sound was comming from the engine somewhere. but this only happens sometimes. any help is greatly appreciated.
Justin35ll
Car: s13 coupe sr20det
you blew the 75amp alternator/battery fuse
its the big gray one in the fuse box under the hood. pull it out and replace
marryson
Car: 240sx
thank you so much
Justin35ll
no problem, don't try and drive it like that because you wont make it far. The battery may last 5 to 10 minutes until you fully drain it and the car shuts off
