100Dollar240 »
https://forums.nicoclub.com/100dollar240-u12664.html
Sun Jun 13, 2004 5:26 pm
I'm sure this topic exists somewhere, but my keyword "alternator" search found nothing pertainent. I began the process of attempting to replace my '93's probably original alternator with a new one. The car's up on metal ramps, the fiberboard belly pan is off, & I fumble with the lower bolt, finally removing it. Hmmm..... can't see any more bolt-heads down there. Let's go topside. Can't see much here, must be buried under all this, uh...crap. I remove all them hoses attached to the air intake. I swing the air intake out of the way & say "hello" to the throttle body. Uh,oh; more little rubber hoses, & the radiator hose sure takes up a lot of work space. Well, at this point, I still don't see any bolts except for what looks to be the horizontal belt tension adjuster. At this point, I decided to consult a higher power, the on-line guru. I'm from the days where you opened the hood, there was the unencumbered alternator staring you in face with two SAE bolts clearly visible. I guess the good old days died with emission controls & down-sized cars. So....at this point, what else needs to be removed in order to at least find the bolt(s) that remain? Any trade secrets to make this, what I thought would be a simple job, actually simple? All free advice certainly welcomed.
Ron.
