lovemy200sx »
https://forums.nicoclub.com/lovemy200sx-u20194.html
Sun Sep 26, 2004 10:14 am
Hello all-
Me and my 200sx (102,500k) have been together about three years. This is the very first problem I've ever had... so I don't know what to think.
I was driving home from the grocery store, with my air conditioning on low. Out of the middle of nowhere, the a/c kicked on full blast, and the BRAKE and BATTERY lights on the dash lit up. None of the other lights, just those two. The radio didn't die, nor did the car run any different. I immediately turned off the a/c. Just as soon as the problem started, it stopped. I got into the parking lot of my apartment complex (about 1.5 mi) and the problem started again; vent kicking on full blast and the battery and brake lights. I sat and listened to it run, watched the temp. gauge and watched the tachometer for a couple minutes, and everything seemed fine, except for those two lights and the vents on full blast. I shut off the car for about 5 minutes, and when I turned it on again the lights were off; vents were back on low. I didn't leave it on long enough to find out if the problem would kick up again.
I called my father (an ex-mechanic; now builds bridges for a living) and he said that it probably isn't the alternator, that it sounds like a relay problem. He also said that he doesn't know jack about cars newer than 1985, so I should ask around.
I have a half hour each way commute to work every day, and I'm assuming that I shouldn't drive it. Any help at all would be appreciated.
Thanks so much-Holly
