wouldnt this be an issue with or w/o the altenator?dattodude wrote:I reckon you have a fat 12v cable, that is somehow not behind a fuse, that is touching the chassis. The fat cable to the starter motor is not fused. that would be a likely candidate. Find a friend ..preferably human, and get them to look for sparks in the dark.
If you can't wait for dark. get into that side with a bright torch (www.dealextreme.com) and look for frayed or worn insulation on fat 12v cables.
Right. It didn't test good. I was able to jumper it and get everything working. I'm going to Nissan tomorrow and see if I can find a new one.mod_mastaz wrote:There isn't an alternator fuse(that I know of anyway). It's a fusible link.
I would start with the coil pack ground...........Katapl wrote:p.s. it seems to be getting a very small yellow spark. i doubt it's a healthy spark at all. would a crap spark possibly be the issue, and where should i start on that?
sounds like the clicking is coming from the starter. it cranks over nicely, but it just won't fire up.
Modified by Katapl at 5:34 PM 4/4/2008
that it fires fine..... how is the mirco switch under the clutch? Mine wore out and stopped the car from turning over(just clicked). I would give that a check too. Is your battery voltage good? this much time with alternator issues and such....Katapl wrote:p.s. it seems to be getting a very small yellow spark. i doubt it's a healthy spark at all. would a crap spark possibly be the issue, and where should i start on that?
