alternator question
JOLTnPEST
i have an Sr20DET and i belive (90% sure) my alt is going and i wanted to know if i could just go to the auto parts store and buy a sr20de ALT and put it in my DET or if the DET is diffrent in anyway?
thanksJosh
pgt892
Car: 1997 240SX
Well the sticky in this forum entitled SR20DET parts guide states "The only parts you really need to get from Japan are the starter, alternator, water pump, and headgasket. Most everything else can be found locally or adapted to fit." So I am guessing an SR20DE alt won't work.
slow s13
Car: cars, photo, music
Im shure you can use the KA24de one because I just put mine on my SR. The pulley is one rib smaller so all youl have to do is swap pulleys or just get a smaller belt.
SpeedRacer1
Car: 1990 240SX, G35
Either get the KA24DE alternator and swap pulleys, or email some of the engine supply shops (heavy throttle, phase2, srswap, jspec) as they carry SR20DET alternators.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
If you will get a KA24DE alternator, consider getting an upgraded one, around 150amps
BlockHead
the sr20de alternator does not work, it will blow the alternator fuse.
Tartan
Car: 89 240sx
Ok my alternator just died on my redtop tonight. Does the KA alternator fit as long as I switch pulleys? What did you end up doing JOLTnPEST?
