Alternator question
Logan76
Car: Junk
i gotta base zenki, and my alternator went out of it, i can pick up an SE model alternator for 40$ locally and save alot of time n money...but theyre 90amps when the base are 80amps and i know people upgrade their alternators to a larger amperage all the time, i just wanted to know if it would all work out fine for me to use the SE one on my base?
onosqv
Car: '92 240sx Vert
yes, it will work fine
Logan76
Car: Junk
Thanks thats all i needed to know.
ricebike
2002 Quest
2005 Altima
just have it bench tested before reinstalling that salvageyard part...
I did after buying a junker, only to find it failed on the diodes/regulator/and amp output tests....
oops, i mean the regulator was bad= if i had just installed that part, I woulda have a blown battery from excess overcharging.
so swing by to advance auto/napa/autozone,etc before doing the R&R job twice!
