so what am i going to need to make this work because its already installed it just wont charge the batteryallensteiner wrote:it puts out 110amps, not 135. you'll need a new relay - 4th gen uses a 120amp and a battery that won't blow up from the extra charge.i don't feel like going out to check right now but pretty sure it's clockwise.
how would i check if the relay is blown?allensteiner wrote:it won't charge because i bet yours has a smaller amp relay. check it and if it's blown put in one from the 4th gen. sorry for missing words in earlier reply. when i said it uses a 120amp it meant the relay/fusible link.
fyi...you'll get over 110amps charge when the alternator is over 9000rpm, but i don't know what eng rpm's that would be.
if you need help locating all that check the fsm: nicoclub.com/FSM/maxima/1994
i know ive asked too much already but do u have a part number b.c all the parts places ive called either have no idea or cant find it in their systemkbflip02 wrote:
even the parts department at the nissan dealership has been unhelpful....kbflip02 wrote:i know ive asked too much already but do u have a part number b.c all the parts places ive called either have no idea or cant find it in their system
