onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue Jan 25, 2005 5:09 pm
Hi all, - car: 89 240sx automatic Ok, I've finally narrowed down the source of the squealing from my engine bay, it seems to be from the alternator/pulley itself, not so much the belt. The reason I believe this is I removed the belt (something I have a question bout also) and turn the alternator pulley and it made a slight squeaky noise. This noise is much worse once the engine starts and at low rpms (will stay at high rpms also sometimes).
My 1st question: How do I change the alternator pulley? Is it hard/advisable to change the alternator itself (it has been about 16 years )? It took me a whole day to do my starter, so any guidance will be helpful.
Also: How are you suppose to take off/put on the belt for the alternator/water pump pulley? I tried loosening the bolts above the alternator pulley (2 that look like similar to the tension bolts on the PS pulley) but the alternator wouldn't budge. I also saw a 12/14 mm bolt at the bottom of the alternator below the pulley but afraid of breaking it. The alternator and pulley are not budging. Currently I'm running a slightly larger belt (360) instead of the belt I'm suppose to be using (355) bcs I am running an underdrive pulley and that was the only way I can get it on for now.
Please help, I can't STANDDDD this SQUEALINGGGG!
Thanks!
