What do you mean by nothing? What are the readings if you pull it directly from the battery? What are they comming striaght off of the Alternator?NickWendt03 wrote:ive got a multimeter and have checked them both but nothing, and the batterys basically new.
what kind of wire did you use? does it, small threads or thick threads? when relocating a battery, you should always use thin stranded, thick gauge wire or it can cause charging issues.NickWendt03 wrote:the only thing i can think of is i relocated my battery. Theres only a 0 gauge wire running from the trunk to the engine bay thats connected to the harness do i have to run a seperate wire from the alternator to the battery??
