240marcuSX »
https://forums.nicoclub.com/240marcusx-u5199.html
Sat Mar 04, 2006 3:01 pm
I keep killing batteries.
I have replaced my battery 3 times, and my alternator once, and i still keep killing batteries.
My friend is a Lexus technician and has tested for parasitic draw on the battery, there is none, He has tested for continuity between the battery and the alternator, and there is continuity, I have removed the alternator and had it tested where i bought it (autozone, rebuilt Nissan, duralast alt.) and it passed their test.
The car will run for about 1-2 weeks fine without dying on me, and then my battery will go dead and not be able to start the car without a jump.
What are some things that I could look for that could be causing this, I need to figure it out because i have some distant races coming up and need the reliability.
I have removed the wiring for the antenna, door ajar lights, aiv, among a few other things. When i say removed, i mean i have cut the wires to make them shorter and neater, to remove uneccesary harnesses. I have wrapped each wire separately with electrical tape to make sure they're not grounding out or touching each other, could this have anthing to do with the problem?
please help me, thanks for your time.
