westhigh66 »
https://forums.nicoclub.com/westhigh66-u73600.html
Tue Aug 26, 2008 1:29 am
After starting the car, there is a bearing noise coming from the alternator or water pump - I can't tell which.1. How do I determine if it is the water pump or alternator.2. The noise goes away after a few miles. It is out of warranty. Should I have it fixed? 3. How long can I drive with a bad bearing?4. Can they just put a new bearing in or does the alternator (or water pump) need to be replaced?
Thanks for your help.
