Dabizzo1 »
https://forums.nicoclub.com/dabizzo1-u52713.html
Sat May 24, 2008 1:54 am
Assuming it is the original alternator, i'd replace it just due to age. Unless the abs motor is humming(relay), I'd assume the diode packs inside the alternator cannot keep up. Decade-plus HEAT is the killer. Cyclic heat. Combined with the fact that our alternators are bottom mount, gunk inside the windings act as an insulator to worsen things ventilation-wise due to road grime (mine was filthy even with the belly plate on). Dim display lights to me are a sign of a charging system that cannot keep up for a hidden reason. My brand spanking new oem replacement cured my premature battery dying woes. Check your cables first as a fine toothed comb inspection...it was a culprit in my case as well. This is the first car I've ever seen with corrosion on the negative cable frame mount point with cracked cable windings to boot(it was a Dallas commuter car before I got it...HOT). Check the peripheral connections first for continuity...could buy you some time on a replacement. Boris
