boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Tue Jul 13, 2010 2:13 pm
Something's not being done right. Is your battery in the stock location or did you do battery relocation swap? When you crank it on your car, what kind of output is the alternator giving you? Will the car run with the new alternator installed? Do you have anything sharing power with your alternator power? So many questions, but it's very hard to determine what the problem is until some of these questions get answered.[/quote]
my battery is in the stock location. when i cranked it the alternator output read at 12.9 and i dont believe anything is sharing power with the alternator. i followed the sr dash connector swap quide is it possible that one of the underneath dash wires not being hooked up could have an effect on its charge? and dee the wiring harness has a brown wire not attached to anything that comes out of the same area as the alternators plug and grounds didnt know what this wire was for.
would belt adjustment effect it performance?[/quote]
Your alternator is not performing correctly at 12.9volts. It should be at 13.5-7 or greater (depending on load). The belt should be tight enough with at least an half inch deflection. Don't sweat the brown wire..........
