I have an issue with my charging system that i believe to be a wire harness issue. I took the alt to a alternator rebuild shop and they did a load test. Its passed. good i guess.
i bought a new fusible link. no luck.
i looked at all the connectors for a burnt wire/connector.. all good.
- blue connector good : E32 > A1
black connector good : E33 > A2
Alternator plug good : A6 alt harness
all grounds good.
- From Alternator Harness + Engine room Harness
plug name:
A3
A4
A5
https://drive.google.com/drive/folders/ ... sp=sharing
My car was an Auto to Manual.. I truly thought i bought a manual Alt harness.. but would this affect me with the ERH being auto?
i googled an found some interesting things about this plug.. on converting auto alt to manual.. but i don't believe mine is a auto..
to my final questions:
1. How can i confirm this is not an auto alt harness...
2. Would this cause my Charging System issue?
- a. My alt wont charge my battery.
thank you for the help.. i been stuck on this issue for weeks now..
