mattmc13 »
https://forums.nicoclub.com/mattmc13-u44312.html
Fri Jul 28, 2006 1:28 pm
I have a '92 240sx SE with (HICAS) 105,000mi on it.
i've had the car for seven yrs but have only driven it seasonally for about 4 of them. i recently put it back on the road and im having a major charging system issue ( i think).
everytime i start my car I HAVE TO REV THE ENGINE TO 3000RPM directly after start up otherwise it will stall out and have a dead battery. also the EGR relay will start to "buzz".
I have tested and replaced the relay already and checked the engine ground with a multimeter but those 2 seem to check out just fine.
I was once told that i might have a 2 stage alternator and that it may not be charging on the low stage.
If anyone could confirm this or share some sort of solution or simalar problem. i would be very grateful.
Thanks. Matt
