O5Q45 »
https://forums.nicoclub.com/o5q45-u267923.html
Mon Sep 18, 2017 5:55 am
Q451990- that is exactly how it happened.. and boy oh boy did it make the car crazy as hell- at one point we were looking at ECM’s and checking flash costs... this was after I thought something was wrong with the rear passenger window.. it was the first signal.. the FIRST system to get shut down or act erratic is the Skid Control computer controlling VDC SLIP and also with it the ABS. I noticed through all our trial and error and after I replaced the ECM relay, that every time (4X’s) the battery got down those systems shut off first.. I also found an easy test, turn on rear defroster, set fan to high, turn on headlights, seat heaters, radio.. and then pull both passenger and driver window switches while the windows are closed, if you get rapid clicks then there’s a issue with voltage in the alternator. That test is with engine running- if no clicking, then you’ve got enough flow from your alternator... thanks to EdBWoy for all the help- and Q451990 as well- winterize those Q’s boys... I think we going to have a hard one-
