As per the other thread for test AC: less than 100 mv AC to test diodes. Amperes: Req's special expensive toolJesda wrote:Can the alternator be tested without removing it?
I think its trouble too. Though it really seems like a matter of just moving all the crap out of the way.Rex wrote:Am I the only one that thinks Jesda + DIY = trouble?!?
I have to give him credit for even contemplating taking on this task, now if he does it, I'll nominate him for DIY'er of the month (a prestigous honor that does not yet exist)
That's only part of the job. You have to remember the order to put all the stuff back, know how to install it, and not break any of it. Replacing the alternator is a deceptively frustrating job. Much more 4-letter words used then when doing the fuel pump or the struts.Jesda wrote:
Wrong!Altiman94 wrote:There is no way that those tools will be sufficient. Holey crap man, take that car in. You really have not a clue. Wes, help this man out. Id do it if you were in Iowa, but obviously this is not the case.
Ya, you should get a breaker bar.AZhitman wrote: Although that ratchet looks a little wimpy.
I dunno... I doubt the sockets are any sturdier than the ratchet. If that's one of them real cheap sets I'll bet you bust a socket. My father is the sultan of cheap tools. Not sure how many I broke growing up. According to him, of course, I didn't know what I was doing and I was overtorquing things (even when loosening them, apparently). Only when I got older did I learn that good tools will never break before the fastener. It wasn't me, Dad!AZhitman wrote:^ Very true - Good advice there.
Jesda, you should be OK with those tools. Although that ratchet looks a little wimpy.
Standard chrome sockets are just fine. I usually get about 90lb-ft of torque from them, before they break. As long as you don't use them with an impact wrench, they will suffice.DAEDALUS wrote:
Yep. I buy all my tools on sale. I got a set of impact wrenchs for $5. normally $30~$45. They can take up to 350lb-ft of torque.DAEDALUS wrote:To be fair, I will say that some of the cheap tools out there are pretty darn decent. I don't mind going to harbor freight for cheap, specialty, low-risk tools that I'll only use once or twice.
I'll try to find the bill. IIRC it was a Bosch alternator. I got it from Autozone.Q45tech wrote:Please provide installed pictures of a 190 AMP BOSCH ALTERNATOR installed on your Q45 and a copy of the bill for $300...........not that I am doubting your WORD BUT lets get real here!
Hehehehe. The reason that those alternators that you are refering to require extra cooling is because they are inefficient. Meaning they generate too much heat for what they do.Q45tech wrote:My searches show water cooled 190 amp alternators [for use on 2004 Audi A8 $1200], and giant air duct cooled models for BMW] and aftermarket rewind 190 amp alternators but their sizes are larger than the Q45 alternator. Most require an external rectifier stack.Ford has some for diesel trucks but they are $800.
the Q45 just starts to pull hard at ~3000rpms. So, that's where it usually runs for me.Q45tech wrote:As who wants to run the engine at 3300 rpms [alternator at 7,000 rpm] to get the full rated ouput of the alternator.
Nope, it came with a larger pulley. I think it maxes out at ~10000rpms.Q45tech wrote:The oem alternator is less than 7" thick from belt pulley tip to the wiring terminal end. The main problem is that most alternators cannot survive the rpm of the Q 6900 rpm multiplied by pulley ratios yield over 15,000 rpm!
Standard alternators put out ~50amps at idle. I think that they reach peak output at ~2500rpms.Q45tech wrote:High ampere alternators have a disadvantage in that they produce lower amperes at idle speeds than optimized 90-110 ampere units! Why even Lexus only uses a 100 ampere unit.
