Oceanblue wrote:the engine didnt even crank.... any ideas of what needs to be done?
Not the alternator. The alternator's not a factor if you're powering it from another car.
It could be your technique. A not-quite-dead battery draws some current recharging. Hook up the jumper cables and start the other car. Let it idle for 1/2 hour or so. Then get someone to rev the other car a bit while you try to start your car. Drive immediately to an auto parts place and get a new battery.
If it still won't turn over, get thee to a mechanic.
