Alternator Dead Due To Fog Lights?!
Clatch
Ok, I left my aftermarket fog lights on and it drained my battery naturally. So of course I go to jump it with my other car a Toyota Avalon. When I jump it, the car just makes a vacuum noise and a strong smell of gas is present. Then I attempt to start the car with one of those portable jumpstarter things and it turns over, but immediatly dies after I remove the booster cables. Now this sounds like the alternator is dead, but it died from accidentally leaving the fog lights on?!
Silvia007
Car: 93 Nissan 240SX SE Fastback
No it can't die from your fog lights being on. All that'll do is drain your battery. If your alternator was good before the jump, then the jump probably killed it.
fatboy
Car: s13
wiggle your battery cables
