Never ever throw away a diesel specific part, don't turn them in as cores either, starters and alternators get rebuilt as they are hard to find when you need them.
I thought that you were the member here that had to find another Vacuum pump that got broken when you were mounting it onto your rebuilt alternator, and then you found this alternator with the vacuum pump on it, what happened to that alternator, why can't you mount the vacuum pump on that alternator?
OK, this is how the wires have been explained to me, the solid white wire in the plug is connected to a keyed source of power from the fuse block, it basically turns the alternator on, when you turn the key off while the engine is running, the power is turned off which turns the alternator off, that is why the light comes on until the engine quits turning, as it is not creating power anymore.
The white/blue wire that goes to the light in the dash has power on both ends, the light gets power from the fuse block, and the alternator supplies power also at its end while it is running, so if the alternator fails, then instead of that end of the wire having power, it becomes a ground which allows the light to come on telling you the alternator is not making power anymore, the light will not come on when it has a power source at both ends.
The main output post on the alternator is connected to the battery in some way by a larger wire, it charges the battery when the alternator is being turned by the engine, sometimes to clean up the engine bay, guys will connect the white wire from the plug directly to this main wire as it has power all the time, so the moment the alt starts turning it creates power because it is excited all the time as it is connected straight to the battery, for some reason it does not drain the battery wiring it this way.
This is all I know about about the alternator, I do have a 3 wire alternator myself, but it is not like yours, and I don't have the original plug with 3 wires to look at the color of the wires, mine has a regular plug hole, it's not like yours where the wires come out of the alt to a plug, mine the extra wire is automatically deleted, it just has no wire going to it but the plug still inserts into the hole.
Here is my plug, it looks like the upper right of the plug is deleted(no wire, upper left hole in this photo from this angle).
Here is the alternator 3 plug hole, upper right spade is deleted.
Here is my 2 wire plug, no upper right spade/wire.
Maybe this will help you, maybe it won't, I did pull out my 1985 diesel harness to see if that part of the harness was in the box, it was not in the box which kinda depresses me because it is not complete.
scottfelsen wrote:The old alternator wasn't working... Its gone. The wire that burned up came from either the pole or from one of the wires on the plug that goes into the alternator. I get continuity from both of them to the end of the positive battery cable... I am not sure what is normal in continuity testing on these wires...
