alternator compatibility? rb ,vg ,vq ,ka, ca?
stlthftr1
Car: 1978 280z with rb25det
are any of the usdm alternators compatible on the rb 25det?
GIJOE69
Car: Going Side Ways!
Heard you can use a nissan quest van alternator with some modifications or get it rebuilt with some sort of mitsubishi power regulator?
Carl H
the quest alternator will bolt on to the block with some boring of the mount bolts but the bracket will have to be modified to come forward and down.
mello88
Car: s13
GIJOE69 wrote:Heard you can use a nissan quest van alternator with some modifications or get it rebuilt with some sort of mitsubishi power regulator?
Yep the 110a Quest alternator can be retrofitted like Carl said
Regarding fitting a mitsubishi power regulator to a stock RB alternator - I have not heard of this being done. Do you have any more details on this? I asked my alt. rebuild shop about increasing the output through additional windings (not realizing they could potentially swap the regulator) and was told the alt chassis is too small for that kind of upgrade. They suggested I retrofit a single wire GM alternator (available in super high outputs) with custom bracket(s) but I haven't looked into this yet.
Shocker
Car: 89 240sxHB rb26/30
Carl H wrote:the quest alternator will bolt on to the block with some boring of the mount bolts but the bracket will have to be modified to come forward and down.
on the 25 some of the material on the block itself needs to be removed after those steps in order for the stock belt to work. Also the long washer/cylinder that acts as a spacer on the lower bolt mount needs to be shaved so it has a flat spot as well.
dsm
Car: 2g AWD
I didn't need to touch the adjuster bracket for richard's(rb240det) car. I just got creative with the way it mounted to the alt. All that it took was an extra bolt and nut and some washers for shimming.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
just a thought but i did some research on this very thing and i found out that the 95-98 maxima's 130amp and should be able to work also
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
one of my friends rb26 s13 he retrofited the ka24de alternator on his rb
mello88
Car: s13
That's interesting, I'll have to look into this.. Are the dimensions similar to the Quest alty?
300Plus
Car: 1995 S14 w/ Rb25det Series II
dsm wrote:I didn't need to touch the adjuster bracket for richard's(rb240det) car. I just got creative with the way it mounted to the alt. All that it took was an extra bolt and nut and some washers for shimming.
any pics of it installed? and any of the installation process ?
stlthftr1
the quest is vg powered right?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Yes, Depending on what year you get it fromI know my mom has a 98 Mercury villager which is the same as the Quest.Both are built by Ford.
stlthftr1 wrote:the quest is vg powered right?
dsm
Car: 2g AWD
I don't have any detailed pics, but you can buy the car( its in the For Sale section) and see for yourself...j/k I will try to get a few shots for you.
