Maybe you guys can help me with this issue I'm having.
I've added a few electrical components to my 1990 300ZX Twin Turbo i.e. Electric Cooling Fan, aftermarket gauges, and a moderate sound system. I plan on adding a Electric Water Pump, and an Electric Power steering Pump. BEFORE I add these items I noticed a charging issue but it was a small issue so I ignored it.
But when I added the first electrical component, (E-Fan), the issue got worse. When the engine is cold, the charging volts are normal, around 13.9v at idle. when the car heats up the charging voltage slowly decreases. Sometimes when I go over bumps or drive through a puddle, the voltage fluctuates up and down. (weird.. I know). When I take the negative teminal off the battery, the engine sputters to a stop. I Thought it was a slipping belt, then a bad battery, and alternator, Changed all and the problem still exists.
Do you guys have any Idea what it could be? Maybe a bad harmonic balancer on the crank underdrive pulley causing the belt to slip, a bad water pump, (it wines like a supercharger when the engine is cold), with an off center pulley causing the belt to slip, bad ground. Or do you think I need to upgrade the wire to 1/0 AWG-which I intend to do before I install the new MechMan 220 amp H.O. alternator I plan on purchasing? I really want to find out the whats causing this be for I invest in a third alternator.
Thanks!
