benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Wed Nov 17, 2004 4:38 pm
No. I meant leave the battery out of the car entirely. A car does not need a battery to run. You would just connect whatever you're using to jump it to the battery connectors.
When you say you charged the battery in the car, do you mean you used a battery charger to charge it or you let the running engine charge it?
If you charged it with the engine, then it is most likely that this act killed the alternator.
If you charged it with a charger, then it is probable that the battery was so damaged that it drew too much current while you were driving it and killed the alternator.
At any rate, the alternator could have been saved had the proper precautions been taken. It is always wise to charge and test a battery out of the car anytime it has been completely drained for the sake of the alternator.
There is also a chance that the alternator may yet be good, and the battery was so damaged that it did not allow an accurate reading when the mechanic was checking the voltage. I recommend you ask him to bench test the alternator once it is removed, and test your battery outside the vehicle as well. From what I've heard, your battery sounds toast.
