AxiOn419 »
https://forums.nicoclub.com/axion419-u32499.html
Tue Nov 27, 2007 10:17 am
Going from memory here, so my directions may be a little bit off. Look on the backside of the alternator bracket, you will see a 12mm bolt. Loosen that bolt. Now, look at the tip of the bracket, there is another 12mm bolt there (right next to the battery tray). That is the bolt you use to loosen or tighten the alternator. Adjust it as you need and be sure to re-tighten the bolt on the backside. Also, thats how it is done on the rb20, I can only imagine it is the same or very similar on the 25. Hope that helps.
