alternator/battery issues?
lostmenoggin
Car: 1989 Nissan 240sx ca18det swapped
So now I'm having problems with my charging system. My battery was going dead today so I checked it with the voltmeter while the car was running and it only read 6.something and the car barely ran. I took it out, put the charger on it and put a KA alternator on the motor. I put in another battery that i know is good. Anyways, the alternator isnt charging the battery. When I put the voltmeter on when it is idling it reads low, about 11.8. I've tried using 4 (FOUR) different KA alternators that I've kept off of different cars/motors I've owned because I knew they worked. It's safe to say I'm pretty good at changing alternators now
I was wondering if these are symptoms of a bad alternator, battery, or both.. I just can't believe none of the 4 alternators fixed my problem. I've checked my grounds and they appear to be ok. Any ideas?
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
I ran into this problem on a couple of my friends cars as well. One was on a battery relocation job and they did a bad job splicing the B+ cable. And the other one turned out to be excessive resistance in the B+ between alternator terminal and battery post. We replaced the wire and it worked like charm. I would ohm out that wire I just mentioned and see if your having the same problem. Especially if you are using a known good batteries and alternators. If everything works out you should be getting around 14.4 volts at the battery and between the battery negative terminal and B+ terminal at the alternator. Good luck with it and let us know how it goes.
Wei
lostmenoggin
Thanks man. The B+ is the big wire on the back of the alternator held on with a nut right? it was only reading .72v. Can I just run a new wire straight to the battery?
anumeric
lostmenoggin wrote:Thanks man. The B+ is the big wire on the back of the alternator held on with a nut right? it was only reading .72v. Can I just run a new wire straight to the battery?
Yup thats the wire. Thats what I ended up doing for my friend, I just ran a new wire straight from alternator to the battery. And once I knew that had fixed the problem I just heatshrinked and taped up the end of the old one and it worked out great.
Wei
syphrus
Car: 92 240sx coupe CA18DET
Is the alternator off my motor ok? If not ill talk to Advanced, i just got it not that long ago, maybe i can get it replaced, or get some of my...actaully your money back. Ill check in, im pretty sure most of the alt.'s get warranties.
lostmenoggin
LOL. i dont think YOU even needed to replace the alternator. I just checked and the black plug on the fuse box wasnt even plugged in. DOH!! I just went outside and started checking volts and i noticed it. alternator is charging at 14.45 volts YESSSSS!!!!!
syphrus
****! nicely done... simple=good. Ill still check and see about advanced. That alt. was expensive, i can try to get you some cash for all the trouble.
lostmenoggin
hells yea man, that would be cool as ****. let me know about that asap.
the black plug down by the fuse box had so much corrosion in it. i sprayed a bunch of brake cleaner in it to clean it out and it works now. took her to get inspected and she PASSED!! not that i had any doubts hehe. the head guy at the place i went to told one of the other guys to check out the exhaust and i almost pooped. stock sr20 o2 housing followed by that 3 inch welded ex. with no cat lol. the dude that checked it said "yea, it's all there" lol. whew. its a loud little ****er though. boosted up to 5 psi. need to put one of the fmics i have on it. i'm rambling. /done
syphrus
F-N awesome man!!! Glad all is well. Like i said, sorry it caused problems, but glad all seemed easily resolved. Ill stop by advanced today and ill let you know. money's money. Let me know when you get a chance to ride down, id like to see it the way it should be.
anumeric
Awesome glad it turned out to be as simple as that. Grats on getting it on the road and passing inspection.
Wei
lostmenoggin
Thanks! I'm glad mostly everything is resolved. Tomorrow I have to figure out why my gauges quit on me. No tach, speedo or temp. The speedo didnt work when i got it. The fuel gauge still works though. I just finished hooking up my fmic. I have it mounted on the other side of the radiator support so it shortens the IC piping and moves my new mishimoto 2 row aluminum radiator closer to the engine. I also hooked up my FAL 210 elec. fans. All I need to do now is buy a smaller battery or do a relocation. There is maybe an inch and a half between the fans and the motor.
syphrus wrote:F-N awesome man!!! Glad all is well. Like i said, sorry it caused problems, but glad all seemed easily resolved. Ill stop by advanced today and ill let you know. money's money. Let me know when you get a chance to ride down, id like to see it the way it should be.
Yea man, if they can't do a refund I'd just exchange it for a new one. This one has something rattling around the inside. Cash is always good though hehe. When I get everything finished I'll definately drive out there so you can check it out.
syphrus
For the guages, check the fuse box. The fuse will not be blown, but if you lift up on the dash fuse, the gauges will work. Short in a wire maybe? i just wedged something between those fuses, so it stayed lifted up. Dont know if that made sense, but if you mess with it youll see what im talking about.
