alternator amperage
s13ragtopkid
hey all,i am installing some amps that produce pretty good amounts of power (1600 watts) i figured out the amps that this is, and its around 86. what i was wondering is how much does the alternator produce, and is needing that many amperes going to produce major problems. thanks. any solutions will also b welcome, thanks.
joe
yellow_jacket
Car: 95 240sx
I would hope that you wired all of this directly to the battery. Running that much power you will be near or over the rating of the alternator(It may only be a 60 amp alternator). Anytime you are running the alternator at or near wide open you will probably burn them up rather quickly.
s13ragtopkid
ya, its all wired directly onto the battery terminal....and i think the 86 amp draw is at full volume, and that much power at full volume would blow my brains out, so if i keep it below half, i think i will b good
180fan
Car: 89 fastback
stock 240sx alternator is spec'ed at 80amps.
U12 2NR
there are higher output alternators for the hardbody's, duno if it'll work on a 240, but worth checking out. http://www.4x4parts.com
ricebike
2002 Quest
2005 Altima
get a lifetime-warranty unit n replace when they do go out on u... unless you're too lazy to R&R it.
