BBISHOPPCM wrote:I know a guy who runs aircraft fuel in his motorcycle, swears by it (only $8/gal)
In which case, he's spending about $3/gallon too much. Actually, about $5/gallon too much, since the aviation fuel isn't really giving him any benefit and is possibly harming the bike.
I own a small plane, and was once approached by a couple of teenagers with jerry cans asking me to buy aviation fuel for them. It was ironic, since I had a couple of jerry cans myself, and had just gotten done filling my airplane with fuel I'd bought from the Chevron station down the road.
There are three major differences between aviation fuel and autogas:
1. The aviation fuel is 100 octane, which is a measure of knock resistance, not an indicator of how much "power" is in the fuel. Your vehicle *can* perform better on aviation fuel, but must be specifically set up to handle the higher octane (and set back down when you run car gas, or the engine will ping like crazy).
2. The aviation fuel contains lead...about four times as much lead, in fact, as the old leaded car gas. Modern car and motorcycle engines are designed to operate without lead, so running on leaded fuel does NOT do them any good. It clogs the oxygen sensors the car's computer uses to monitor the engine status, for example. It kills the catalytic converter (which is why lead was eliminated from car gas to start with). Both things will really hose you up if you live in an area that requires regular emissions checks.
3. It is much more stable than car gas, i.e., it won't start to break down if the vehicle doesn't operate for a couple of months.
Ron
