Alt. options?
RS12Turbo
I think my alt. is crapping out. It's showing 13.1 volts at idle with no load. Cruising it's 13.0-13.1 volts. When the electric fan kicks on it drops to 12.8-12.9 volts. Battery is a brand new Optima.
Is there a direct replacement from another Nissan?
killedbydeath
Car: Nissan 180SX
the 88 pulsar NX2000 (north american car)
uses a 1.8 CA18DE.
same alt. sir.
RS12Turbo
yes yes...i'm aware of the pulsar with ca18de.....but is the alt the same..since it's fwd set up?
I found a thread a little while ago that said there were no alt options and to get it rebuilt......if a ca18de alt. will work..then that will make life much easier. Can anyone confirm for sure?
killedbydeath
Car: Nissan 180SX
damn it, no i cant remember if i ended up replacing mine.. lol.
go buy one, try it out, and if it doesnt work, take it back.
i remember the tool behind the counter trying to figure out the ground lead on mine, off the 180sx, to the conventional 88 pulsar's, the only solution is to try it i guess.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
just have it rebuilt. they can even rebuild it to produce more AMPs for a few bucks usually.
mazikowski
Car: 2013 Subaru BRZ Ltd 6MT, 1984 CA20E 200sx, 1981 L28E 280ZX
The Pulsar alt is not the same... it mounts on the exhaust side of the block...
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
anybody have a general price range on an alternator rebuild?
sjbsuperman1425
CA18DET
RS12Turbo wrote:I think my alt. is crapping out. It's showing 13.1 volts at idle with no load. Cruising it's 13.0-13.1 volts. When the electric fan kicks on it drops to 12.8-12.9 volts. Battery is a brand new Optima.
check the connections on the alternator..i had the same problem except my voltage was in the 12's and 11's. i had a really bad corroded wire on the alternator. now its 14v at idle, and with the fan, lights, walbro, and 5 gauges the lowest it goes is like 13.4v
ca18detgabby
03 Infiniti G35
sjbsuperman1425 wrote:anybody have a general price range on an alternator rebuild?
cost me 80 bucks for a stock rebuild and 100 for extra power at a local shop
took them a hour or two IIRC. it was real fast right after I first did my swap.
sjbsuperman1425
CA18DET
yea for us, i say go rebuild..$100 no b/s and it will bolt right back up. i mean you'll probably pay $100 for another one anyway right?
RS12Turbo
Rebuild it is....although I will check the connectors as mentioned above.
Cams
Car: 1993 Nissan 200sx CA18(DET) RS13
2002 Mitsubishi Airtrek JDM 4G63T (wife)
2013 Scion FR-S
2016 Infiniti QX50
I have a similar issue. Voltage starts at around 13.5-13.8 and decreases pretty quickly down to 13.1-13.2 without fans turning on. Once my FAL fans kick in (19amps) the voltage drops to 12.7 - 12.9. An it gets worse during the night with the lights on.
Have tested 2 CA alts, original rebuilt and a spare bought here (supposedly rebuilt) without much progress.
Also worked some more ground cables and even and extra positive from alt to battery to improve charging.
Improved only a bit lately after fiddling with the fan controller. Set them to turn on at a higher temp but does get scary to see the needle move slightly pass the middle of the gauge.
Don't know if the shops here can rebuild mine to make it give more power, and wouldn't know where to start checking bad wiring.
