MrShawn305 »
https://forums.nicoclub.com/mrshawn305-u242387.html
Sun Jan 18, 2015 3:27 pm
I have the exact same problem on my truck. The only difference being mine is not intermittent, it simply blows the fuse. If I replace the fuse they all work and then after a minute or two the fuse blows again and the gauges stop working. Just like yours, everything works except the turn signals, gauges and the bat light is on. I can drive it all day long as long as I don't shut it off and the alternator will keep running the electric fans, roll bar lights and everything else. Did you ever find out where your problem was? I did notice that it started happening to mine last night after I I had it pretty high sideways navigating some rocks. It didn't bottom out, scrape or anything like that, it just articulated a bit. Maybe something got pinched somewhere?
