NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Mon Sep 12, 2005 4:06 pm
disconnect the battery lead[the one that was stripped] unplug the grey connector plugged into it. Then set your multimeter on Ohms. lowest setting. Place your red lead on the battery lead[ the one that was stripped] and place your black lead on the body of the alternator. If you meter registers you have a direct short to ground[ the body of the alternator] Your meter should stay on infinite[ I ]
