leesredgt wrote:i was running factory boost, my avc-r was off i dont even have it set up yet.and to be honest with you i didnt even look at my temp gauge i was trying to feel what the car was doing.
ill have to pull the plugs tomorrow if i get home before dark.i did notice one thing diffrent, when i parked the car i smelt a burning smell, not like omg im on fire smell, but like a slight smell i dont know if it was the new plugs, it almost smelt like burning brakes.also to make sure i done this right when i set the timing i set it to the 4th mark down is that right?
The forth mark is 15 degrees. I am having the same problem. I just put my motor in, new plugs, new timing belt, new fuel pump, and last night checked for boost leaks. I have read on hear something about setting the tps I havet done that yet. Would this be causing our problems? I don't have an adjustable FPR and I noticed when I pull the vac line off and drive it it runs 100 percent better. But dumping fuel.
