alright guys i need some help
anou
how hard is it to remove the entire dash? b.c im planning on painting my interior. and how long will it take to remove the dash? thanks
PapaSmurf2k3
Site Admin
by the time you get a good reply to this, it could probably be mostly done. just start removing screws and remember where they go. start by taking off the kick panels, and then some more screws will be revealed.
tonynalli
take the vents that are closest to the windshield off and there are screws that come off there. take off the two big switches off(hazard light, and healight pop up) there will be one 10mm bolt on each side of that, take off your radio bezel and the coverings for the steering wheel and once those are gone there might are two on either side of the kick pannel. you will have to drop the under cover (dont know what it is officially called) that is under the steering wheel with 10mm bolts and there will be like on other, just look it might be a little hidden, and then pull and look for stuck spots. dont be afraid to pull hard, thats what i had to do to get mine out. i believe that should be all
